[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 576: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 459: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 133: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4790: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4792: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4793: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
Mustang Club de France • Consulter le sujet - jeu direction DA
jeu direction DA
jeu direction DA
Message par mustang 66 » 19 Nov 2014 14:35
salut a tous ;j'ai fait changer les silenblocs moteur les rotules les biellettes de direction et j'ai un jeu plus important qu'avant ; quand je tourne le volant de droite a gauche moteur tournant a l'arret ; il y a un jeu important avant que les roues se mettent a bouger :( et quant je roule et que je prend une bosse la voiture sous vire !. c'est quoi a votre avis? le mécano m'a dit de la ramener mais c'est inquiétant quand meme. pouvez vous me dire ce que c'est? merci pour vos réponses.
mustang 66
Message(s) : 134
Re: jeu direction DA
Message par petitluc » 19 Nov 2014 15:14
Salut je ne sais pas comment est la direction mais j'ai eu le cas sur une voiture de 30 ans. Le croisillon de renvoi d'angle qui est entre le boitier et le volant HS donc presque 1/8 ème de tour entre gauche et droite sans bouger les roues.
petitluc
Message(s) : 162
Numéro Adhérent: 1964
Message par mustang 66 » 19 Nov 2014 20:34
merci pour ta réponse; mais normalement elle devrait etre plus stable vu que les pièces son neuve ; il faut que le mécano la regarde !
mustang 66
Message(s) : 134
Message par crayon » 22 Mars 2015 18:56
C'est le boitier de direction qui est à régler, c'est courant, réglable et connu de tous (sauf ton mécano à première vue)...change de garage!
Laisser partir une auto avec des travaux sur le train avant faits et rien sur la direction, c'est inacceptable...
Cordialement.
Crayon
Message(s) : 5058
Message par mustang 66 » 22 Mars 2015 19:11
salut ; je l'ai ramener chez lui et il l'a conduit le mécano a remarquer le boitier un peu user mais pas de danger ! par contre les pneus étaient légèrement sur gonflé ; depuis je l'ai vendu a un spécialiste de la marque donc pas de soucis ; en tout cas merci d'avoir répondu!! a bientot!
mustang 66
Message(s) : 134
