[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 576: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 459: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 133: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4790: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4792: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4793: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
[phpBB Debug] PHP Warning: in file [ROOT]/includes/functions.php on line 4794: Cannot modify header information - headers already sent by (output started at [ROOT]/includes/functions.php:3912)
Mustang Club de France • Consulter le sujet - CLIPS tuyau embrayage S-197 ...enfin!
Message par crayon » 25 Mars 2016 11:53
Bonjour à tous!
Pour ceux qui ne savent pas où trouver le fameux clips qui verrouille le tuyau hydraulique d'embrayage, voici son petit frère jumeau!!! :dance:
En effet, le clips d'origine est A NE PAS PERDRE :angry-screaming: lors du démontage de la ligne hydraulique (réfection embrayage, Upgrade du tuyau)!!!
Ce fameux clips n'est pas détaillé chez Ford et se vend donc... avec l'émetteur ou avec le raccord coudé sur la boite (mais je ne suis pas sûr car rien vu sur le site "FordsParts"). :roll:
Le problème est connu sur les forums US, beaucoup demandent de l'aide en cas de perte.
Les références de substitution US que l'on peut trouver chez d'autres constructeurs ne correspondent pas forcément avec l'équivalent en Europe (j'ai commandé plusieurs clips chez Ford, BMW, Peugeot Europe et rien n'allait)... :confusion-shrug:
Donc pour ceux qui, comme moi ont transpiré lors du petit "chhhttiiinnnnng"! d'un clips qui se fait la malle et qui reste introuvable, voici de quoi vous sortir d'affaire! :happy-bouncyblue:
Référence VW 7MO-721- 431
Cordialement. ;)
Trouvé chez Volkswagen !!!
Le clips coté émetteur d'embrayage.
Le clips coté BV, il y en a deux!
Message(s) : 5058
Re: CLIPS tuyau embrayage S-197 ...enfin!
Message par fredo08 » 27 Mars 2016 07:20
ou la solution passer en tuyau et raccord avia et dérivation pour la purge , mieux que le plastoc cassant
cab66 pony coupé 67 gta mach1 1970 fox lx sport 302 92
fredo08
Message(s) : 3768
Numéro Adhérent: 757
Message par crayon » 28 Mars 2016 15:32
J'ai monté un tuyau inox en remplacement de celui plastique et c'est impeccable.
C'est lors de ce changement que j'ai perdu le clips... :roll:
Le montage type avia ne résout pas ce problème, l'émetteur ne peut pas recevoir de raccord filetés...
Message(s) : 5058
Message par fredo08 » 28 Mars 2016 17:47
Tout à fait. Sauf á changer le raccord de butée
fredo08
Message(s) : 3768
Message par crayon » 29 Mars 2016 08:08
Oui, pour le récepteur (ajout de la vis de purge) mais pas coté émetteur... ;)
Message(s) : 5058
